0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 156 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 156 | From my understanding, if there is a horn relay, there would be dual horns. I have seen a used low tone 12v. I presume the other would be a high note? This is for a '54 Chevy that I converted to 12v. So far I have not seen any high not horns.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system. JB Weld..."I put that stuff on everything"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 1954, a horn relay was needed/used with the standard one "sea shell style" 6v horn, and with the two "sea shell style" 6v horns (inside the grill - low).
In 1953, I think that no horn relay was needed with the single "old style" horn. (maybe someone can confirm/correct this?)
However, I think that a 6v relay was needed with the 1953 optional "dual sea-shell style" 6v horns, which were mounted on a bracket on the manifold.
I have also seen these mounted on a bracket on the firewall. | | | | | Joined: Feb 2021 Posts: 156 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 156 | I may settle with a single low tone 12v sea shell horn then (cheap, used on ebay). I'm not sure if I need a 12v relay. I'm sure my existing is 6v.
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | relays are all about the amp draw. and what wires you are running like up your steering column. a relay draws maybe 1/4amp to activate the switch or less therefore you can run much smaller wires up the column. Horns draw from a few amps up to 24 or more therefore you need much bigger wires. Longer wire runs mean larger voltage drops. Not a big deal for a horn but other systems it becomes a issue.
Engineers put relays in for a reason not just to add more parts. Look at your whole layout if the switches and wires are all large enough to hand the full loads through the circuit a relay may not be required. But if that ground wire up to the horn switch is small then pull a new wire or run a relay. | | |
