11 members (55shaker, Doug Boudreaux, Steveoreno, 1955 1 Series, Bill Trotter, dt235sd, Jethro in Va, 3B, Wingnut68, moparguy, Peggy M),
69
2
Mod | | | Forums66 Topics128,197 Posts1,057,400 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,186 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,186 | Are 3100 spindles specific to each side? Or can they be reversed? The spindles are not side specific. A check of the parts list shows only one number for both sides all the way thru 57 on half tons. They apparently are year specific though, with the ones for Huck brakes, thru 50 different than the later spindles.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | |
Entire Thread
Whatcha putt'n off & King Pins and bushings and motor mounts, just do it.
| moparguy | 01/21/2022 3:26 AM |
Re: Whatcha putt'n off & King Pins and bushings and motor mounts, just do it.
| 78buckshot | 01/21/2022 11:20 AM |
| dgrinnan | 01/21/2022 1:22 PM |
| Just Mark | 01/22/2022 7:29 PM |
| JW51 | 01/21/2022 2:48 PM |
| Green_98 | 01/21/2022 3:39 PM |
| JW51 | 01/21/2022 6:25 PM |
| LeeD | 01/22/2022 6:11 PM |
| 52Carl | 01/22/2022 11:09 PM |
| 78buckshot | 01/22/2022 9:46 PM |
| Just Mark | 01/24/2022 5:04 PM |
| fixite7 | 01/25/2022 4:29 PM |
| Just Mark | 01/26/2022 12:31 AM |
| Barnfind49 | 01/26/2022 11:56 AM |
| tclederman | 01/24/2022 8:46 PM |
| 78buckshot | 01/25/2022 12:41 AM |
| Just Mark | 01/25/2022 1:41 AM |
| moparguy | 01/25/2022 2:17 AM |
| fixite7 | 01/25/2022 4:24 PM |
| fixite7 | 01/25/2022 4:39 PM |
| moparguy | 01/25/2022 8:18 PM |
| TUTS 59 | 01/25/2022 12:59 PM |
| moparguy | 01/25/2022 8:30 PM |
| Mike B | 01/26/2022 1:12 AM |
| Barnfind49 | 01/25/2022 10:52 PM |
| JW51 | 01/28/2022 11:17 PM |
| 52Carl | 01/30/2022 1:47 AM |
| Leo | 01/29/2022 7:55 PM |
| JW51 | 01/30/2022 3:13 AM |
| 78buckshot | 01/30/2022 4:20 AM |
| klhansen | 01/30/2022 4:45 AM |
| JW51 | 01/30/2022 1:46 PM |
| 52Carl | 01/30/2022 3:31 PM |
| klhansen | 01/30/2022 10:44 PM |
| JW51 | 01/31/2022 3:04 AM |
| klhansen | 01/31/2022 8:00 AM |
| tclederman | 01/31/2022 3:13 AM |
| moparguy | 01/31/2022 3:15 AM |
| EdPruss | 01/31/2022 4:22 AM |
| JW51 | 01/31/2022 1:51 PM |
| klhansen | 01/31/2022 6:45 PM | |
