| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Will the warmed up engine crank if you use a 12V boost? It sounds like something might be binding up inside the engine like pistons fitted too closely the the cylinders. Is the engine freshly rebuilt, or does it have some miles on it?
