Can you help me with the location of the clutch/brake pedal shaft bushing set. This is Bowtiebits PN AD-475-MEC-938. I don’t see bushings in the Assembly manual (section 5, sheet 2.00j unless they are supposed to be the 3684453 “spacers” shown on that page. I ordered these figuring they are a wear item and would likely need to be changed.
M. Hayden
