2 degrees before it starts to ping, under a load. I don't think the timing and a lean burn is your problem. I would look at a plugged radiator or a stuck or missing thermostat being the culprit. Borrow a digital thermometer and start looking for cool spots in your cooling system. I did see one far out scenario one time, a waterpump had rusted the impeller fins completely off of the pump, not moving any water at all. That one sucked to diagnose. Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
