0 members (),
110
2
Mod | | | Forums66 Topics128,285 Posts1,058,276 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Unless someone has changed it, the pedal actuates the master cylinder (that is included with the brake master cylinder) which engages the slave cylinder on the right side of the bellhousing. V-8's and 6 cylinder vehicles of your vintage were designed this way. Other years had a pedal that actuated some linkage to engage the clutch arm on the left side of the bellhousing. I suppose you could fabricate some linkage or find some from a later vehicle to accomplish this feat. It sounds like you know how to make it work. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
