I know how later horn buttons work but need to understand how yours works to explain the difference. Basically the newer have the wire attached to a upper mast bearing which is a combination bearing and slip ring. The wire comes up the column, stays below the bearing and is no factor.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
