If there was still oil oozing from the bottom of the housing that sealant won't stick. Generally for that stuff to work the surface has to be completely clean and dry and it has to set up for several hours before filling with oil.
Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes
1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes
2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans
1947 Willys CJ2A w/F-Head engine
