3 members (BC59, Rusted Nut, 1 invisible),
120
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Connect a temporary jumper wire from the big battery cable terminal at the starter to the upstream (ignition switch) side of the coil, and spin the starter. If the engine starts, find the dirty or loose connection at the back of the ignition switch or somewhere else upstream. A bad connection will show 12 volts in a "open circuit" situation, bit it won't flow enough current to make the coil work. Dirty contacts INSIDE the ignition switch can do the same thing. Jerry
