7 members (cmayna, 55shaker, Gray_Ghost, Otto Skorzeny, Hotrod Lincoln, MikeE, 1 invisible),
131
3
Mod | | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | The .86 overdrive should work fine with the 3.38 ring and pinion. That 3.38 would not be ideal with a .73 overdrive. You would have to reach 70 MPH before you shift into 5th gear. The 3.38 will also make that steep first gear more useful. You will be floored how a T-5 wakes up a Stovebolt engine. Every time you shift you will be in the optimal powerband of the engine. No more lugging after every shift, then make the engine scream before the next shift so that it doesn't lug again. As you can see, 52Carl is a T5 convert. Yes, I agree Carl. It’s a great combination of gears and axle.
Entire Thread
1946 1/2 ton T5 conversion, with a twist...
| TradToolworks | 07/23/2021 7:33 AM |
Re: 1946 1/2 ton T5 conversion, with a twist...
| WE b OLD | 07/23/2021 10:16 AM |
| Lugnutz | 07/23/2021 11:06 AM |
| Lugnutz | 07/23/2021 6:04 PM |
| Lugnutz | 07/23/2021 7:23 PM |
| Wheelie | 07/24/2021 12:24 AM |
| Wheelie | 07/24/2021 12:36 PM |
| Fox | 07/24/2021 5:39 AM |
| WE b OLD | 07/24/2021 10:00 AM |
| Wheelie | 07/24/2021 9:47 PM |
| WE b OLD | 07/24/2021 11:51 PM |
| Wheelie | 07/25/2021 11:12 AM |
| Lugnutz | 07/29/2021 11:02 AM |
| Lugnutz | 08/01/2021 2:50 AM |
| Lugnutz | 07/30/2021 11:14 AM |
| Lugnutz | 07/30/2021 10:17 PM |
| Lugnutz | 07/31/2021 2:38 AM |
| 52Carl | 08/01/2021 3:02 AM |
| Lugnutz | 08/01/2021 3:28 AM |
| Lugnutz | 08/01/2021 9:11 PM |
| Lugnutz | 08/01/2021 9:12 PM |
| Lugnutz | 08/07/2021 6:47 PM |
| Lugnutz | 08/07/2021 8:05 PM |
| Lugnutz | 08/08/2021 5:03 PM | |
