| | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 81 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 81 | My T5 and driveshaft are from an '83 S10. The adapter came from Hot Rod Works and mounts a 1982 thru 1992 T5 to a 1937 thru 1947 bell housing. I did have to cut the driveshaft down but that's easy, just ask the driveshaft shop what measurements they need and $150 later your down the road. I'm running a '58 1/2 ton rear end with a 3.38 gear so that's just like yours. Don't get too worked up about your overdrive ratio unless you've modernized your front suspension and brakes. I don't find it to be a usable gear until around 60 or 65 mph which is faster than I care to drive my original suspension.
Steve
1946 1/2 ton
Entire Thread
1946 1/2 ton T5 conversion, with a twist...
| TradToolworks | 07/23/2021 7:33 AM |
Re: 1946 1/2 ton T5 conversion, with a twist...
| WE b OLD | 07/23/2021 10:16 AM |
| Lugnutz | 07/23/2021 11:06 AM |
| Lugnutz | 07/23/2021 6:04 PM |
| Lugnutz | 07/23/2021 7:23 PM |
| Wheelie | 07/24/2021 12:24 AM |
| Wheelie | 07/24/2021 12:36 PM |
| Fox | 07/24/2021 5:39 AM |
| WE b OLD | 07/24/2021 10:00 AM |
| Wheelie | 07/24/2021 9:47 PM |
| WE b OLD | 07/24/2021 11:51 PM |
| Wheelie | 07/25/2021 11:12 AM |
| Lugnutz | 07/29/2021 11:02 AM |
| Lugnutz | 08/01/2021 2:50 AM |
| Lugnutz | 07/30/2021 11:14 AM |
| Lugnutz | 07/30/2021 10:17 PM |
| Lugnutz | 07/31/2021 2:38 AM |
| 52Carl | 08/01/2021 3:02 AM |
| Lugnutz | 08/01/2021 3:28 AM |
| Lugnutz | 08/01/2021 9:11 PM |
| Lugnutz | 08/01/2021 9:12 PM |
| Lugnutz | 08/07/2021 6:47 PM |
| Lugnutz | 08/07/2021 8:05 PM |
| Lugnutz | 08/08/2021 5:03 PM | |
