| | | Forums66 Topics128,212 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Found mine at Ace Hardware but that was about 7 years ago....I also made my rod from a piece of rod stock and then using my dremel cut the slot....and had a friend to tack the butterfly with a welder. It takes a little time but well worth the effort.
...you may find when you get it apart that the "slop" in it is caused due to the bushing worn out on one side. Just be sure to make the positions as you take it apart... even draw you a picture! Let us know how you do. | | |
