In the past I've used co2 in the tank to weld them up. Co2 is non combustible and heavier then oxygen. If you don't have a tank of co2 drop a piece of dry ice in the tank. When you put an open flame to rusted metal, rust starts popping loose all over the place. You may end up with a lot more pin holes than you can shake a bronze rod at.
