I doubt that's a locker or limited slip differential. You can check by sticking an axle into one of the side gears and turning it. If it's an open differential, the pinion probably won't turn, but the opposite side gear will turn the opposite direction. If it's a limited slip, the pinion will turn if one axle is turned.
