0 members (),
154
3
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Sorry it took so long. Original removed windshield and the truck it was removed from: Windshield top to bottom = 15 13/32" (the edges of the windshield glass are slightly rounded). Windshield side (face) of pinch weld top to bottom = 15 30/32" Difference = 17/32 = 0.53125 Div. by 2 = 0.265625 = tight, if expecting 0.5
I used a right angle held against the pinch weld and pushed to the top. Same on the bottom pushed down. Measured with a scale from the right angle edge to right angle edge. Even with all this hoopla, paint, rust and unevenness of the window channel.... Thank You ! This really helps. The Steele Rubber thickness is .320/.325 so if you have .266 that means a crush of .054" which seems plausible. The "glass guy" said he needs .250 all around for it to fit well. Your measurements make his comments accurate. Appreciate the help!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | |
Entire Thread
Windshield woes on 1954 Chevy 3604, help needed
| Dusty53 | 09/19/2020 3:42 AM |
Re: Windshield woes on 1954 Chevy 3604, help needed
| KEVINSKI | 09/19/2020 4:18 PM |
| Dusty53 | 09/20/2020 12:03 AM |
| tclederman | 09/19/2020 4:46 PM |
| Dusty53 | 09/20/2020 12:33 AM |
| tclederman | 09/20/2020 1:02 AM |
| Dusty53 | 09/20/2020 1:08 AM |
| tclederman | 09/20/2020 1:13 AM |
| Dusty53 | 09/20/2020 1:47 AM |
| Trevor J | 09/21/2020 7:46 PM |
| Dusty53 | 09/21/2020 10:09 PM |
| tclederman | 09/21/2020 7:49 PM |
| buoymaker | 09/21/2020 11:51 PM |
| Dusty53 | 09/22/2020 11:11 PM |
| klhansen | 09/22/2020 11:44 PM |
| Trevor J | 09/22/2020 4:17 AM |
| Phak1 | 09/22/2020 11:27 AM |
| Dusty53 | 09/22/2020 11:10 PM |
| Trevor J | 09/22/2020 11:47 PM |
| tinnerjohn | 09/23/2020 12:13 AM |
| Dusty53 | 09/23/2020 1:39 AM |
| Dusty53 | 09/23/2020 1:34 AM |
| klhansen | 09/25/2020 6:15 AM |
| Nuts&Bolts | 09/25/2020 3:11 AM |
| Dusty53 | 09/25/2020 4:50 PM |
| buoymaker | 09/26/2020 12:36 AM |
| Dusty53 | 09/26/2020 4:08 PM |
| buoymaker | 09/26/2020 7:27 PM |
| Dusty53 | 09/26/2020 7:35 PM | |
