8 members (Gray_Ghost, Biermann, Hugh63c10, SmalltownTRKGuy, Phak1, Buckeye998, Gdads51, dt235sd),
138
Mod | | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,865 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,865 | The seal is toast anyway. Drill a small hole in it and put a good sized sheet metal screw into the hole. Then use a claw hammer or a carpenter's wrecking bar to pry the seal out. Be sure not to drive the screw in where it messes up the part number- - - -your parts guy might need to cross-reference it. That's an old 18-wheeler seal trick. Jerry
