Originally Posted by Gord&Fran
I used the setup from an early 70's pickup which I picked from a wreck. I salvaged the pedal assembly, armoured cable and all the bits and pieces attached to it. The pedal assembly fit nicely between the firewall and the dash. A new hole was drilled in the dash and the armoured cable was routed down under the truck next to the speedometer cable. Didn't take any pictures but maybe I should take some since you are the second guy to ask...
Thanks for the input. Just not sure what I need. I need to look at my truck and see if the holes are there for the original pedal assembly. Not sure if it bolted under the dash, to the side wall, or the floor.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
