If you plan to do more brake work in the future, and would use the tools again, buy them and do it yourself. If you want quick and easy, check out
www.inlinetube.com They have pre bent kits for ~$150-$175. I used Inline tube, everything is pre bent, cut, flared, and has the right fitting. There is some experience, trial/error, skill to making double flares, personally, I do not possess that skill!!
Jon
