In Alaska, you are required to have a CDL to drive anything over 26,000 lbs. You need extra endorsements for air brake, combinations (truck/trailer) or anything carrying HazMat. Medical card and random drug testing for CDL Background check for HazMat, and you are required to report any ticket to your employer within 24 hours. I worked at Anchorage Int. Airport, the job required I have Class A CDL with endorsements including HazMat which required a background check, random drug testing, and post accident drug testing, To work on the Airport Operating Area, background check, random drug testing, post accident drug testing,and airport I.D. card. The company I worked for had the same requirements, plus the company owned an off site tank farm at the harbor in Anchorage which required, you guessed it, backgound check, random drug testing, post accident testing, a Mar Sec Id card, and none of the entities would accept anybody elses' background checks!!
Good luck!
