Issue 1 - new or rebuilt carburetor?
Issue 2 - if you replaced the vacuum advance, and it still does not move, did you check to see if the plates in the distributor move? If not, definitely a problem.
Issue 3 - political problem (garbage gas).
http://www.thecarburetorshop.com/Troubleshooting.htm#Hardstartcold
Jon.
The Carburetor Shop
