The pictures will show my problem. The 60 truck has two plastic connectors that go through the firewall. I do not want to destroy anything even though I plan on replacing them.... So, what is the proper procedure to remove these connectors??? Does the plastic come out of the rubber molding or???? Do you pull it into the cab or out through the engine bay???
1960 C20 Apache Step Side Long Bed
"Swamp Thing" restoration
Story starts in 60-66 trucks
