| | | Forums66 Topics128,095 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,101 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,101 | You should be able to swap the wires at the switch to get the switch to go from OFF to LOW to MEDIUM to HIGH. That assumes there are 4 wires to the motor. If there are only two, there are resistors in the switch. Did the original motor work the way you want? If you had someone do the work, it sounds like they wired it incorrectly if the operation is different than original.
