If I ain't mistaken, the tire size you listed are trailer tires I think.???
Yep, any tire that starts with ST is a trailer tire. You can use passenger tires on a trailer but not trailer tires on a passenger vehicle.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
