| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,858 | The spacer also serves as a heat isolator, preventing "heat soak"- - - - -fuel boiling in the float chamber and flooding during a short shutdown like refueling, etc. Even if you need to install longer studs, the spacer should really be there for correct operation. Jerry
