| | | Forums66 Topics128,109 Posts1,056,261 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | 55.2 through 59 trucks used a ceramic type ballast resistor as did cars of that era. The resistance "wire" was introduced in the early 60's. Your 64 truck came with a resistance wire unless someone changed it out for some type of HEI system that requires a full 12 volts to operate. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
Entire Thread
Resistance wire, what years.
| beltfed | 07/11/2019 1:49 AM |
Re: Resistance wire, what years.
| Hotrod Lincoln | 07/11/2019 1:27 PM |
| coilover | 07/11/2019 3:44 PM |
| Lugnutz | 07/11/2019 4:02 PM |
| BC59 | 07/11/2019 5:01 PM |
| rfs56trk | 07/11/2019 9:21 PM |
| beltfed | 07/11/2019 9:22 PM |
| bartamos | 07/15/2019 7:08 PM |
| Hotrod Lincoln | 07/15/2019 7:15 PM |
| beltfed | 07/15/2019 9:06 PM |
| Hotrod Lincoln | 07/15/2019 9:26 PM |
| Detroit Iron | 09/03/2019 10:55 PM | |
