| | | Forums66 Topics128,101 Posts1,056,175 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I see you're in Tennessee so you might consider just using a resister coil which does away with all the other wires and ballast resister and just requires a regular wire from ignition switch to the coil. You cannot have a 12v by-pass with a resister coil so if hard starting or very cold weather a by-pass is sometimes needed.
Evan
Entire Thread
Resistance wire, what years.
| beltfed | 07/11/2019 1:49 AM |
Re: Resistance wire, what years.
| Hotrod Lincoln | 07/11/2019 1:27 PM |
| coilover | 07/11/2019 3:44 PM |
| Lugnutz | 07/11/2019 4:02 PM |
| BC59 | 07/11/2019 5:01 PM |
| rfs56trk | 07/11/2019 9:21 PM |
| beltfed | 07/11/2019 9:22 PM |
| bartamos | 07/15/2019 7:08 PM |
| Hotrod Lincoln | 07/15/2019 7:15 PM |
| beltfed | 07/15/2019 9:06 PM |
| Hotrod Lincoln | 07/15/2019 9:26 PM |
| Detroit Iron | 09/03/2019 10:55 PM | |
