| | | Forums66 Topics128,115 Posts1,056,636 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | That starter does not have a "solenoid". What are you working on that you're calling one? If you're referring to the push button on top of the starter, that's just a simple switch. The starter drive gear is engaged mechanically, not by solenoid action. try this- - - -super-glue a nickel or a flat washer on top of the switch button. It looks like the foot pedal linkage is not pushing the button down far enough to engage the contacts and make the starter motor turn.
If that trick makes the starter turn, then fix the worn spots on the pedal linkage- - - - -there are several places where holes can elongate or rod ends can wear undersize. There are no adjustments. Jerry
Entire Thread
54' Chevy Starting Issues, Not even a whir
| Montana 54 Chevy | 06/14/2019 2:09 AM |
Re: 54' Chevy Starting Issues, Not even a whir
| baldeagle | 06/14/2019 4:31 AM |
| Hotrod Lincoln | 06/14/2019 5:01 AM |
| Montana 54 Chevy | 06/15/2019 7:51 PM |
| WE b OLD | 06/14/2019 8:37 AM |
| treydrummer | 06/14/2019 10:34 AM |
| Hotrod Lincoln | 06/14/2019 12:53 PM |
| 68ironhead | 06/14/2019 2:11 PM |
| 52Carl | 06/15/2019 1:27 AM |
| TUTS 59 | 06/14/2019 5:07 PM |
| jorb | 06/14/2019 7:13 PM |
| glenns towing | 06/15/2019 1:38 AM |
| Montana 54 Chevy | 06/15/2019 7:47 PM |
| Montana 54 Chevy | 06/16/2019 3:13 AM |
| baldeagle | 06/16/2019 5:13 AM |
| Hotrod Lincoln | 06/16/2019 2:59 PM |
| Montana 54 Chevy | 06/16/2019 4:39 PM |
| Hotrod Lincoln | 06/16/2019 4:56 PM |
| Montana 54 Chevy | 06/17/2019 12:34 AM |
| Hotrod Lincoln | 06/16/2019 5:25 PM |
| jorb | 06/16/2019 7:45 PM |
| Montana 54 Chevy | 06/17/2019 12:36 AM |
| jorb | 06/17/2019 3:36 AM |
| Montana 54 Chevy | 06/19/2019 2:41 AM |
| Montana 54 Chevy | 06/21/2019 5:33 PM |
| jorb | 06/21/2019 6:30 PM |
| Hotrod Lincoln | 06/21/2019 7:18 PM |
| KEVINSKI | 06/22/2019 1:16 AM |
| Montana 54 Chevy | 06/22/2019 7:56 PM |
| Hotrod Lincoln | 06/22/2019 8:15 PM | |
