| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,044 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,044 | So after the tranny is warm, it grinds a bit going into first or reverse. Those gears are not synchronized (second and third are) and after the gear oil is heated up by driving, it gets thinner and gears are still spinning as you attempt the shift. I would consider that normal. All my 4 speed trannys do that (none are synchronized in first and reverse).
I cannot explain the difference due to your change in oil. Perhaps it is because it is summer in Michigan now and the oil is thinner?
Kent | | |
