| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,941 | On the race distributors we used to double-spring the points to eliminate high speed bounce. That was rough on rubbing blocks, but most race engines didn't last long anyway and point life wasn't an issue. Hot-spark coils burned the contacts out long before the rubbing block wore out. Jerry
