3 members (jay d, 2 invisible),
54
3
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,475 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,475 | I prefer to have negative pressure in the engine. So I've made a dipstick which seals with 2 o-rings (fits in the stock dipstick tube) and I use an oil filler cap with a center hole into which a fitting with a reduced hole goes. When I have it choked to the point of what I think is the right engine negative pressure (positive pressure encourages oil leaks) then it goes to a hose which in turn is filtered. On the valve cover, I have made wide spreader bars which keep that sucker pressed down tight out of aluminum...as I recall it was 3/16" thick. You can see them here. https://beta.photobucket.com/u/JonGoodman/p/9ce484b5-5a62-475f-886a-8b51a08ceca0There are 2 of these on each side of the valve cover reaching end to end and meeting in the center.
