| | | Forums66 Topics128,188 Posts1,057,332 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If its the front you should remove the outer bearing & pull the hub/drum off together. You may have to back off the adjustment if the drum is grooved. If the rear drum is stuck to the axle you can go at it with a hammer & penitrating oil. Make shure there are no clips around the studs or rivets to the flange. If its bad enough you may have to heat the drum. Again back the adjustment up so ther is no interference with the shoes.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | |
Entire Thread
Removing brake drums, help?
| LeftEar55 | 03/24/2005 12:52 PM |
Re: Removing brake drums, help?
| Wrenchbender Ret. | 03/24/2005 2:32 PM |
| dale937 | 03/24/2005 2:37 PM |
| Brian Moore | 03/24/2005 3:52 PM |
| Hotrod Lincoln | 03/24/2005 4:07 PM |
| LeftEar55 | 03/24/2005 11:28 PM |
| LAROKE | 03/24/2005 11:42 PM |
| Dad's 65 | 03/25/2005 1:45 AM |
| LeftEar55 | 03/25/2005 4:05 AM |
| Hotrod Lincoln | 03/25/2005 4:13 AM |
| 64fleetside | 03/25/2005 4:14 AM |
| HardyRestoration | 03/25/2005 4:26 AM |
| mugsy | 03/25/2005 4:46 AM |
| 48bigtrucks | 03/25/2005 5:12 AM |
| Fran and Gord | 03/25/2005 5:14 AM |
| InMy40s | 03/25/2005 5:29 AM |
| jgalt_54-235 | 03/25/2005 7:11 AM |
| Dan S | 03/25/2005 8:54 AM |
| Wrenchbender Ret. | 03/25/2005 10:22 PM |
| Wrenchbender Ret. | 03/25/2005 10:23 PM |
| GMCPauly | 03/26/2005 12:30 AM |
Anonymous
| 03/26/2005 2:08 AM |
| shooper | 03/26/2005 2:40 AM |
| 4d9r | 03/26/2005 5:14 AM | |
