Originally Posted by HandyAndy
I was looking at this sway bar from Classic Performance Products for my '47 3100. However, I contacted CPP and was told the center to center dimension of the bar is 21 1/4". Attached is a picture of my front cross member which shows much less than 21 1/4". Could CPP be mistaken?
Has anyone used this sway bar kit? If so, could you provide a center-to-center measurement?
HandyAndy not sure if this helps but it is a link to their instructions on how to install a their sway bar on an AD truck.
http://www.classicperform.com/tech_articles/SwayBarChevyTruck/SwayBarChevyTruck.htm
1950 Chevrolet 1/2-Ton 3100
