ok, i got mine looking just like your pic. it seems to go through the gears fine until i start it, then just grinding. when i put the clutch in, i did have a bit of a concern when bolting it together. the pressure plate didn't bottom out. the bolts were pretty tight but there was still a gap. should it sit flat?
when i installed the trans, the last 1/4 inch needed to be pulled in with the bolts but nothing like i had to force it. what do you think?
really, i can't thank you guys all enough and a big thanks to sstock for having the patience to help me out.
