| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Use a short piece of hose from that nipple and plug it, then. You don't need to be bypassing that much coolant back to the water pump inlet. It's interfering with the operation of the thermostat. Jerry
