| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Pay special attention to the primary wire from the coil to the distributor. It's being flexed constantly as the vacuum advance moves and it can break under the insulation and create a momentary open circuit. As soon as the distributor stops moving the circuit comes back together and you can re-start. I like to use a piece of very flexible test lead wire there. Jerry
