Hi Ron
Thank you for your suggestion - I never thought of a ledge to make it a bit easier to reach underneath - I also have a burned out instrument bulb that I have not been able to replace because of same reason - I must confess though, I am struggling visualizing the setup you describe above - Do I read it correctly that you suggest laying on end in the truck ( middle of cab for example and hang other end out the truck and support it with something to make a ramp or similar? - That sounds like a great idea - did I read that correctly?
Also, to Ed - Thank you for the reminder - the squeaking I haed the last 10 miles or so before the thing broke certainly shouted something is in need of lubrication
Joe Finkelstine
Born and bred in Motown
