| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | Installing a 1954 or 55 1st. series crossmember in the firewall area will allow you to use a 1955-62 V8 bellhousing. The crossmember is virtually a bolt-in swap for the 1950, so no permanent modifications to the frame will be involved. The 292 block bolts onto the V8 bellhousing since all the 3rd. generation sixes have the V8 bolt pattern. You'll still have to deal with the extra length somehow when it comes to positioning the radiator. Jerry
