I just made a clip for my 50 coupe Saturday. Yes, a pan bolt goes through it.
Note: someone will have to verify this..................the throttle spring I used was TWO springs wound together. I suspect that is a safety thing but I do not know if they were double when original. I just happen to have one from a ????? car I worked on one time. Ace Hardware is a good place to "rummage" through their supply until you find what you want....and cheap with no shipping.
