| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Got any pictures of the damage? Likely that the dents have pulled crown out of adjacent areas, resulting in the loose panel and hence oil can. If this is indeed the case you would want to fix the dents first and in most cases it will fix the oil can by default. Pictures and/or a video of the oil can cycling would help in pointing you in the right direction. Here's some other discussion on oil canning: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1254308/help-oilcanning.html#Post1254308
