| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 22 New Guy | | New Guy Joined: Jul 2014 Posts: 22 | We need some help in trouble shooting. I'm really hoping HotRod Lincoln comes to the rescue again.
We've got a '51 1/2-ton with a '54 235 that is only running on 4 cylinders. The #3 and #4 cylinders are not firing. Here's what we've done so far.
Check the compression: 1: 165 2: 160 3: 165 4: 165 5: 160 6: 165
New plugs. We have swapped plugs from different cylinders with no change. New wires. We have swapped wires from different cylinders with no change. New cap and rotor. We rotated the cap with no changes. We checked that the bushings in the distributor are tight and there does not seem to be any wobble in the rotor. Since #3 & #4 share the same intake, we checked the manifold bolts and all is tight. This is a new truck frame off so we even pulled the carb off the manifold and stuck a dental mirror down the throat to make sure we didn't leave a rag in the intake. We have adjusted the valves.
Now what? Anyone else run across this?
Thanks.
Entire Thread
non-firing cyinders, trouble shooting help
| Ken & Sons | 10/01/2017 4:20 AM |
Re: non-firing cyinders, trouble shooting help
| DennisM | 10/01/2017 4:39 AM |
| ApacheFiend | 10/01/2017 8:10 AM |
| tomctomc | 10/01/2017 9:08 AM |
| Justhorsenround | 10/01/2017 2:07 PM |
| Ken & Sons | 10/01/2017 2:31 PM |
| Maybellene | 10/01/2017 3:12 PM |
| Wrenchbender Ret. | 10/01/2017 3:46 PM |
| Ken & Sons | 10/01/2017 3:55 PM |
| Hotrod Lincoln | 10/01/2017 4:10 PM |
| Wrenchbender Ret. | 10/01/2017 4:49 PM |
| JW51 | 10/01/2017 6:03 PM |
| rickmg | 10/01/2017 7:28 PM |
| Hotrod Lincoln | 10/01/2017 7:36 PM |
| truckernix | 10/02/2017 12:56 AM |
| tclederman | 10/02/2017 1:42 AM |
| Roy Rodgers | 10/02/2017 1:56 AM |
| tclederman | 10/02/2017 2:01 AM |
| Ken & Sons | 10/02/2017 2:29 AM |
| Roy Rodgers | 10/02/2017 3:33 AM |
| DennisM | 10/02/2017 3:53 AM |
| Hotrod Lincoln | 10/02/2017 3:58 AM |
| DennisM | 10/02/2017 4:52 AM |
| Hotrod Lincoln | 10/03/2017 1:36 AM | |
