Why wait on one of the resto-ripoff outfits to get enough orders to commission a production run? (which is what they're doing) Any hydraulic shop can make up a set of those lines, using 1/8" NPT swivel fittings on at least one end. Since single braid hydraulic lines are designed to withstand running oil at 3000 PSI and temperatures far above anything stovebolt motor oil will ever get, you'll have a better set of lines with no frustrating wait!
