| | | Forums66 Topics128,038 Posts1,055,583 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I've seen a post on here that describes testing the entire circuit by manually raising and lowering the float and watching to see it the gauge move correctly. Other than that guess you can check it with an ohm meter to see that the circuit is complete. The first indicator for me is if the needle is in the home position just below the empty mark. Other broken gauges I've had the needle is way off. Best of luck and I'm sure others will be along with better info! | | |
