| | | Forums66 Topics128,077 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 112 | Was a problem with the old style boxes back in the day. The box and tube are mounted to the frame. The other end of the tube was mounted to the lower dash. Over time the cab would shift causing an out of line Condition stressing the shaft as it was rotated eventually cracking it.
That's why they went to a Rag joint or U joint. Tom | | |
