If all else fails and you have a wire feed welder you can put a blob on the bolt and twist it out. The heat will probably help too. "A little dab will do ya". If you are worried about getting weld on the head drill a hole slightly smaller than the bolt in a piece of copper and use that as a shield. Grease on the head around the bolt might also shield it.
