| | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Run your differential until it breaks, Which it won't. You need to identify your 10 Bolt. You could have the same size ring gear as a 12 Bolt. The 12 bolt from 64-72 would be a good one to measure. Don't know what HP you are talking. 400HP is no problem for your 10 bolt.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
