tlorber,
Yes you can use an electric vacuum pump to run wipers. I use ones off of old Mercedes diesels that you can get from a salvage yard for twenty bucks. The pump is in the trunk behind the spare tire. With it wipers will run at any speed and never slow down on hills or under hard pull.
Evan
