0 members (),
108
8
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,270 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,270 | Rugo Here's a pic of the donut as it came out of my truck with the tank. It's ~2" dia x 1" thick with a hole to fit the 1/4" NPT pipe nipple (~3/8" OD). As far as I can tell the tank has never been removed prior to me taking it out, so the donut should be similar to what you need. It's a one-piece donut. gas tank outlet donut Hope that helps.
