| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Speedo gear count is subject to diff gear ratio, and tire size. You can use any gear count and correct any amount it is off with a speedo correction adapter. This connects to the outside of the transmission, and the cable then connects to it.
See the USA in your vintage Chevrolet! My Blog | | |
