Hot Rod Lincoln? Charlie Ryan? Commander Cody? Merle Haggard? Did I get hacked and redirected to KOMA. (I could get that from AZ on my Crystal radio kit with the antenna wire connected to the screw that holds the outlet cover on, in my bedroom. Wolfman Jack)(The entire house ground system was my antenna)
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
