I usually blast the manifolds and then put a sock on my hand and rub it in....The toothbrush doesn't work for me and the stuff goes everywhere. I guess I brush to hard?
After applying it helps to run the engine up to temp to cook it and you will have just a "tat" of a smell as the excess burns off. Then, if going to a cruise in I sometime just touch it up.
This is how I do it but it may not be best for everyone and a lot depends on it being on or off the vehicle and how hard/easy it is to get to it....but it does work.
